Question about replacement fiberglass front bumper cover
Old Aug 5, 2010 | 12:57 PM
caphie's Avatar
Default Question about replacement fiberglass front bumper cover
Hello all,
I'm have installed a fiberglass front bumper cover on my 1979. I'm now ready to attach the grills. I'm scratching my head because the new cover has six tabs (3 for each grill) sticking out of it. You can see the tabs I'm referring to in the picture linked below:
http://www.ecklers.com/productmedia/...id/16/image/0/
My question is: do I mount the grill to these tabs or do I cut them off and mount the grill to the original mount points on the bumper within? I ask because it seems like it would fit flush and look good if mounted to the tabs, but it doesn't feel like it would be very secure. If I cut the tabs off and mount inside it kind of looks like the grills will be set back into the cover too far and won't look good.
Would love to hear from someone else who has installed one of these covers.
Thanks!
Old Sep 9, 2010 | 08:06 PM
Unless the bumper sticks out farther than the original, then not sure why mounting to the original mounts would recess it. Do you have another 79 near that you could check?
Old Sep 10, 2010 | 08:09 PM
caphie's Avatar
That's just it... the new bumber does stick out further than the original. I had no idea this was the case until the bumper was painted and mounted. Thought I'd try here since I know replacing the urathane bumber with fiberglass is fairly common.
Old Sep 10, 2010 | 09:16 PM
Then sounds like you'll have to mount to the tabs on the bumper cover. That's another reason I bought a NOS urethane. Won't have to be fitted or trimmed.
mike82
Mar 13, 2010 08:27 AM
David Knight
Sep 15, 2007 10:55 PM
tonyb
Mar 20, 2006 11:47 AM
blue91
Nov 19, 2005 12:50 AM
skinny_kid_mustangs
Aug 28, 2005 10:08 AM
