rear window/75
Old Nov 9, 2006 | 10:22 PM
cortlandfirefighter's Avatar
Default rear window/75
will the removeable rear window of a 72 fit a 75? or does body work have to be done?
Old Nov 10, 2006 | 09:39 AM
Default RE: rear window/75
All I can recommend is that you check with a local glass shop. They can cross refference the specs.
My guess is yes, they will interchange.
Old Nov 10, 2006 | 09:17 PM
thank you.
Old Nov 10, 2006 | 09:51 PM
You're welcome, let us know what you find out.
Old Nov 12, 2006 | 02:26 AM
mrggrm's Avatar
Firefighter, are you looking to install a functional removable rear window or just use the glass out of one?
Old Nov 12, 2006 | 09:03 AM
install..if possable,i haven`t taken mine apart to find out if the holes are their.just tought if someone had a75 who had done that they might know,,
Old Feb 13, 2009 | 01:07 AM
piratejosh's Avatar
Did anyone ever find an answer to this question? I would like to do the same thing.
Old Feb 13, 2009 | 10:45 AM
I thought about doing this when I got mine new when I discovered the the rear glass was held in by strip caulk. It started to get loose and let water in.
I see no reason you couldn't get all of the hardware and make it a removable window. I'm sure it would be expensive and not sure if all of the parts would be available new. Probably have to salvage some or all of them.
myckey2u
Dec 19, 2007 02:42 PM
C4land
Sep 10, 2007 09:50 AM
hedhntr61
Jan 13, 2007 12:27 AM
DANNYCAM
Mar 6, 2006 01:34 PM
Lenticular
Oct 3, 2005 03:48 PM
