REPLACING POINTS
Old Aug 14, 2008 | 06:45 PM
  #11
SCHOON's Avatar
Default RE: REPLACING POINTS
I ordered an electronic igniton kit from Eckers for $159.
Said just toss the points and screw it in.
No such luck, there is some modification work to be done, Not Easy.
If my Vet was numbers matching it might have been worth it.
I sent it back and took the advice of a friend and bought one of those aftermarket GM HEI distributors on Ebay for $119.
Now I need HEI wires and that should be it.
My friend has had one of these distributors in his 66, 427 for 5 years, no problems.
Old Aug 14, 2008 | 08:08 PM
  #12
Does it have a tach drive or did your friend go to an electronic tach?
Old Aug 14, 2008 | 08:14 PM
  #13
SCHOON's Avatar
It is a tach drive, HEI with internal coil.
Old Aug 14, 2008 | 09:31 PM
  #14
Sweet. Didn't know there was such an animal. Learn something new almost every day.
Old Aug 15, 2008 | 03:02 PM
  #15
SCHOON's Avatar
DRAGON FIRE
CORVETTE TACHDRIVE DISTRIBUTOR
Do not be fooled by other's selling copies and look alikes.
The Dragon Fire HEI System has proven to be the best alternative to other Higher Priced ignition systems. It's simply the best bang for your buck, designed specifically for durabiltity and performance. This is the last Distributor you will ever have to buy. Other's may look like it but dont be fooled,there's only one true Dragon Fire HEI System.
We are an established manufacturer of high performance HEI distributors. We have been in the distributor business for 15 years. We are the absolute best source for all your high performance ignition/distributor needs.
Our exclusive Dragon Fire models are the best performing HEI distributors available on the market. We are so assured with the quality of our new Dragon Fire HEI Distributor, that we provide a Lifetime Warranty with it!We also offer our FREE TECH SUPPORT from our highly experienced staff.
The Dragon Fire Tachdrive Distributor Fits:
-All 1962-74 Corvette with Mechanical Tachdrive
-All 327, 350, 396, 427, 450 ENGINES
LIMITED LIFETIME WARRANTY
OVERNIGHT SHIPPING AVAILABLE
FREE PROFESSIONAL
TECH-SUPPORT
CAN BE USED FOR STREET
OR STRIP APPLICATION
__________________________________
Tachdrive
Specifications
50k High Performance Mega Coil
-Made in North America
65% more energy with 42% faster spark breakdown time compared to other HEI’s
-Adjustable Vacuum Advance Canister for better performance advance curve
-High quality bronze bushing for reduced friction and extended life
-Corrosion resistant shaft reduces friction and provides concentric operation
-Fitted with a HEAVY DUTY gear that is ground to exact tolerances for tighter mesh
with cam for years of performance through the harshest conditions
-HEAVY DUTY coil to produce an increased spark
to light the fuel mixture for high performance
-High quality Brass Terminals for maximum high voltage transfer.
-Precision advance weights and center plate eliminate erratic timing.
-Free Professional Tech Support
-Brand New Complete Unit Includes: Body, Shaft, Gear,
High Performance Coil, Cap, Rotor, HEI Module, and Dust Cover.
Shipping/Payment Terms
-Shipping Insurance is available for $3 and is advised for damage protection.
-Our Standard Shipping is $9.95 and normally takes 1-4 days from one of
our three warehouses.
-Overnight Shipping is available for a flat rate of $29.95!
-We currently accept Paypal, Visa, Mastercard, and Money Orders!
-Please ask all questions before purchasing an item.
Old Aug 15, 2008 | 10:19 PM
  #16
I remember in '75 when HEI first came out that GM had to electronically dial back the dwell equivalent at idle cuz the existing plug wires were breaking down from so much voltage.
Old Aug 16, 2008 | 12:17 AM
  #17
pg's Avatar
Seems like you found a good one there, plug and play. I put a Pertronics in my original dizzy and your right, there were 24 steps and I had to take the wholething apart, this seems like a better way to go. PG.
Old Aug 16, 2008 | 06:40 AM
  #18
Texas Jim's Avatar
Always good to know someone who's gone through and been successful at what you're about to do. I'm glad it all worked out well for you.
thomastober
Jul 12, 2010 10:40 AM
SuperHeroSmurf
Sep 29, 2008 06:07 AM
atcdork
Feb 14, 2007 09:39 AM
rjensen
Dec 4, 2006 08:17 PM
rjensen
Nov 30, 2006 02:38 PM
