86 coupe: where are the electrical ground points?
Old Feb 12, 2007 | 10:02 PM
atcdork's Avatar
Default 86 coupe: where are the electrical ground points?
My instrument panel occasionally goes blank (it's still on, just not back-lit) with only the turn indicator and high beam tell-tale lights on. I read that this may be caused by a bad ground. I also read that the ground wire is connected on the firewall somewhere. Can somebody tell me where the ground point for the instrument panel is. I'd like to try to clean it to see if it makes a difference with the instrument panel.
Thanks,
Ed
Old Feb 12, 2007 | 11:25 PM
Default RE: 86 coupe: where are the electrical ground points?
Usually the problem is cold solder joints on the I/P circuit board. Do a search for it on these forums and there is a site that has pics and instructions.[8D]
Old Feb 13, 2007 | 09:33 PM
atcdork's Avatar
Actually, I was going to send the instrument panel off for repairs. The speedo panel needs to be repaired or replaced (it looks like the LCDs are all starting to "bleed" together). But I wanted to check the grounds to make sure they weren't corroded (and also to see if that was was causing the panel to go blank).
I know about the ground strap between the frame and motor underneath the battery. I was just wondering where the other grounds were.. specifically the one that connects theinstrument panel.
Thanks,
Ed
Old Feb 14, 2007 | 09:39 AM
There are 2 grounds relating to cab issues. There is 1 above each kick panel in the interior, there is a ground on the left frame rail just to the front left of the engine in addition to the ground strap you mentioned. [8D]
thomastober
Jul 12, 2010 10:40 AM
SuperHeroSmurf
Sep 29, 2008 06:07 AM
SCHOON
Aug 16, 2008 06:40 AM
rjensen
Dec 4, 2006 08:17 PM
rjensen
Nov 30, 2006 02:38 PM
