Seat belts [68]
Old Jan 15, 2007 | 11:20 PM
Chryco_Psycho's Avatar
Default Seat belts [68]
the outer seat belt [lap] goes under a Chrome plate & under the seat , is this supposed to retract & is therefore siezed or is it just a fixed anchor point ?
Old Jan 15, 2007 | 11:42 PM
drdenny's Avatar
Default RE: Seat belts [68]
Just checked my 68 soft top which I have had since new and it has outer belt attached to floor coming through a black plastic lined slot in carpet about 6in. in width. No retractors. What model areyou working on?
Old Jan 16, 2007 | 12:59 AM
the exact same car , 68 soft top
thanks for checking , I couldn`t see inside the rubber sleeve far enough to to see if it was just an anchor or a retractor
Old Jan 16, 2007 | 02:32 PM
1969 L46's Avatar
I just replaced the carpet and the seat belts in my 69 drop top. The outer belt (male end) is anchored under rear center of the seat under the carpet. The belt goes through the guide that is bolted to the rocker panel. The inboard (female end) belts are anchored to the tunnel. The inboard anchor points are connected under the car by a steel cable.
akabyron
Feb 6, 2008 12:24 PM
akabyron
Jan 19, 2008 12:20 AM
Lucinda
Jan 31, 2007 11:27 PM
jazzdrvette
Oct 18, 2006 01:16 PM
watwheel
Sep 14, 2006 11:43 AM
