Spark plug and wire replacement
Old Apr 18, 2021 | 08:47 AM
BDRUSSELL's Avatar
Default Spark plug and wire replacement
I have a 1981 C-3. Has anyone had the problem I'm having getting to the plugs to replace them and plug wires routed between the block and motor mounts. Two front plug wires cant be removed or replaced with the boot on the wire. Any advice or tips would be greatly appreciated.
Old Apr 18, 2021 | 10:45 AM
74HARLEY's Avatar
When I did them on my '77 a few years back I believe they went under the motor mounts. I don't recall having any issues replacing them.
However, if you are replacing yours I would cut the old ones and look at a more reasonable routing. Good luck!
Old Apr 19, 2021 | 04:56 PM
Welcome to the forum. I think originally the spark plug wires to the front two plugs on each side went through the motor mounts and also had a metal shield on each side of the block. I'll check my assembly manual and see if I can expand on that any.
Old Apr 19, 2021 | 05:18 PM
The assembly manual doesn't show any of the RFI shielding. The only shielding it shows are the heat shields between the plugs and the exhaust manifold. It also doesn't show any detail with respect to the motor mounts. It simply shows the spark plug wires going along the lip of the crankcase pan.
9673vette
Jul 12, 2008 03:45 PM
scottr65
Aug 20, 2007 03:54 PM
Jim2001c5 pilot
Jul 1, 2007 01:53 PM
Sparkplugs.com
Dec 8, 2006 12:21 AM
94blackC4
Sep 25, 2006 09:35 PM
