Speedometer cable leak
Old 11-05-2019, 08:25 PM
Nbingham's Avatar
Default Speedometer cable leak
I'm leaking transmission fluid from the speedometer cable. Looking at the cable and cable gear assembly I don't see how it wouldn't leak. The way the gear fits into the housing there appears to be no seal that would keep fluid from making it's way up into the cable. Am I missing something?
Neild
Old 11-06-2019, 09:26 PM
I would check the level of the transmission fluid or oil depending on which type of transmission you have. It sounds like it might be overfilled.
Old 11-07-2019, 09:25 AM
Nbingham's Avatar
Thumbs up
Through further investigation (Google Search) I believe I found the problem. It appears that the previous owner replaced the seals on the speedo gear bullet and didn't seat the gear shaft seal far enough in so the gear shaft is not in full contact with the seal. I haven't put it back together yet to verify the fix but it appears this is a somewhat common problem.
Thank you for the response.
Neild
Old 11-07-2019, 09:39 AM
Let us know how it works out.
Old 11-17-2019, 04:44 PM
Nbingham's Avatar
Default Before and after
The attached pictures are before and after of the speedometer bullet gear shaft seal. It's easy to see were things went wrong.
Old 11-18-2019, 09:52 AM
Thanks for the feedback.
Nbingham
12-24-2019 10:32 AM
chubbs325
08-02-2013 01:12 PM
riley6riley
05-10-2009 01:49 AM
orangevette
04-20-2008 08:47 PM
johnc
11-05-2005 07:25 PM
Quick Reply: Speedometer cable leak
