starting trouble
Old Oct 30, 2017 | 03:24 PM
orangevette's Avatar
Default starting trouble
My 74 sat for about 6 weeks without being started. Now when I try to start it all I get is a click when I turn the key. I connected a portable jump starter to the battery and again all I got was a click. The lights lit up okay. The jump starter was fully charged. Earlier this summer it ran okay with no problems. Any help is greatly appreciated..
Old Oct 31, 2017 | 07:28 AM
Do the lights dim when you try to start it?
Old Oct 31, 2017 | 09:25 AM
to 73shark: when I turn the key the lights not only dim but they go out completely. Then after a several minutes the lights will come back on and when I try to start it again, they go out.
Old Nov 1, 2017 | 09:01 AM
That sounds like either a bad battery connection someplace in the circuit or a battery that's not fully charged.
Old Nov 1, 2017 | 10:13 AM
I'll put the charger on it again and let you know what happens....
Old Nov 1, 2017 | 06:04 PM
thank you 73shark: It appears the battery is bad. It is 10 years old and finally pooped out. Thank you for your input and help.
