steering column
Old Jul 13, 2006 | 12:41 AM
Fuzzy74's Avatar
Default steering column
I am having trouble because I can not get my key back to the lock position to remove it on my 76' it will do every other function but back to lock so I can remove it. I believe there is a gear that needs set, I do not know how to get to the gear or even if thats the problem, any help would be appreciated.
Fuzzy
PS I put a new ignition lock in already.
Old Jul 16, 2006 | 07:07 AM
cvette's Avatar
Default RE: steering column
Hi:
The same thing happened to me on my 72 four speed, and in my case the nut came off of the reverse linkage rod so it wouldn't go into reverse to activate the reverse lock-out mechanism for the steering.
If you have a four speed transmission, it could be that the reverse lock-out mechanism is jammed, or disconnected. This mechanism consists of a cable that runs from the manual four speed transmission to a lever just below the steering column at the firewall (under the hood). When you lift the T handle on the stick shift and put the transmission in reverse, it pulls on the cable to activate the steering wheel lock. When the steering wheel is locked, then you are able to turn the key back to the lock position and remove it.
I am not sure how the steering wheel lock-out works on an automatic transmission but it is probably similiar.
Hope this helps!
cvette - 72 Coupe!
sorlowski
Dec 3, 2008 07:38 AM
mrbugs
Oct 19, 2006 07:05 PM
Fuzzy74
Sep 14, 2006 05:43 PM
Rick854
Jul 2, 2006 06:41 AM
Gorilla
Sep 16, 2005 02:36 PM
