Steering Column
Old Jun 24, 2006 | 12:24 PM
Rick854's Avatar
Default Steering Column
Hi all,
I have a 2000 coupe and due to the recall a year ago I had the dealer fix the steering column lock problem. Now, the steering column is locked again. I had my car towed to the dealer and their telling me the column is no longer covered under the recall.
My question is, if the problem persists then would it still be covered under the recall?
Another question is can the mechanic find out what the problem is without opening the steering column?
Any feedback would be appreciated.
Thanks.
Old Jun 28, 2006 | 10:07 AM
Default RE: Steering Column
I'm not entirely sure at this point, but I think it is a programming issue with the body control module. I'll have to check TSB's at my shop when I get there and let you know.[]
Old Jun 29, 2006 | 10:02 AM
According to the GM TSB #04006C dated Feb. 2006, the steering column lock plate should be removed and the PCM reprogrammed. If it is still locking on you, they obviously didn't remove the plate. Go back to them and ask them about it.
Old Jul 2, 2006 | 06:41 AM
Rick854's Avatar
THANKS FOR THE INFO.
IT APPEARS TO BE WORKING AGAIN. AFTER MY CAR WAS SITTING IN THE SHOP FOR A WEEK THE STEERING COLUMN APPARENTLY BECAME UNLOCKED ON ITS OWN. IT'S BEEN WORKING FINE ALL WEEK, BUT I'LL TAKE YOUR ADVICE AND TAKE IT BACK TO THE DEALER TO MAKE SURE THEY DO TAKE OFF THE LOCK PLATE AND REPROGRAM THE PCM. I JUST HOPE IT DOESN'T TAKE THEM ANOTHER WEEK.
sorlowski
Dec 3, 2008 07:38 AM
mrbugs
Oct 19, 2006 07:05 PM
Fuzzy74
Sep 14, 2006 05:43 PM
Fuzzy74
Jul 16, 2006 07:07 AM
Gorilla
Sep 16, 2005 02:36 PM
