Stock manifolds VS headers
Are you referring to the short pipe extensions that are inside the exhaust manifolds?
Although it's too late now, for future reference, there is a brass plug available witha straight pipe thread that will fit the AIR holes in the manifold.
There where no threads, the AIR pipes were integral, and I really had no problem just leaving them, because the check valves prevent the exhaust leaves, but it just makes it SO much easier to do tune ups if they are out of the way.After Icut them up, I realize that I probably could have taped them andthreaded in a plug, but why spend all that money onfancy welder if I never get any practice! GOD BLESS INDIANA!
I guess you have different manifolds than mine then. Mine had a flare nut hold the external pipes on and then there was an internal extension pipe that fed the air right next to the head of the exhaust valve. I didn't know about the extension pipe and when I took the manifolds off, the ends of the extension pipe were melted back about 1/4".
man, sounds like you did some traileri'n or over heatin' for your exhaust to get that hot, I will see if I can put some pics of my manifolds, and my squeaky clean engine up in the next couple days
No I just had removed the belt on the AIR pump so there was no cooling air for a long time and then removed the external piping and put the plugs in, so still no air.
Looking forward to your pics.
There were two SMOG systems used, one was AIR, Air Injection Reaction which had a Smog pump, and then PAIR, which was Pulses Air Injection Reactor, which had no Smog pump, but I thought most of the PAIR systems came on straight sixes and such, not the V8's
HI DayCreamer, I was just courious, I have no emissions devices on my car and never had any problem passing inspections, I was told that it mattered where the car was to be sold, seems like North Carolina doesn't care about pollution and I never had a problem at inspection time. Also was told that after a car is 35 years old we don't need any more inspections, so June will be my last inspection.
PS, hope all goes well on the mod's your installing. PG.
