stock valve size
Old Oct 10, 2006 | 09:16 PM
whiteray's Avatar
Default stock valve size
I have an 80 with the L-82 and i was wondering what size valves i have.
and possibly rear end gears but from what i understand there was about six rear end options
Old Oct 11, 2006 | 12:34 PM
Default RE: stock valve size
I'm guessin' valves are 1.94's.
Rear end.....
get one rear wheel off the ground, leave trans in neutral.
Mark the drive shaft and the rearend housing at a common point.
Rotate the tire one full rotation and count the rotations of the drive shaft.
This will get you real close as to the ratio of your rear end.
3 turns, 3.07:1
4 turns, 4.11:1
These are rough numbers, but will get you in the ball park.
Texas Jim
May 20, 2009 05:53 PM
exhaust_guy
Sep 1, 2008 01:08 PM
chargedvette02
Jun 19, 2007 02:20 PM
jds_truck
Nov 22, 2006 01:13 PM
Petew1971
Mar 7, 2006 02:04 AM
