Think I may have a transmission problem.
Old Dec 25, 2008 | 03:49 PM
Rickcusaf's Avatar
Default Think I may have a transmission problem.
I was taking the vette out for a nice cruise and decided to open her up a bit. I have a TH350 with a 2400 rpm holeshot stall converter and a hurst shift kit. The transmission was rebuilt less than 35000 miles ago also and strengthened.
I dropped down into second opened her up and then shifted into third. Once I got up to about 85 I noticed that the car started running really rough. I let my car drop back down to about 40 and noticed that when I accelerate from 40-50ish it seems to run really rough. It still goes and all the gears still work, but I'm not sure what the problem is.
I got back to my house and put her in neutral and slowly depressed the pedal. When I got up to higher rpms my engine backfired slightly.
I popped the hood and checked the fluid level and the smell. The fluid level was fine, the fluid itself was still red, and it did not smell burnt. Any ideas?
-Rick
Old Dec 25, 2008 | 05:52 PM
Rickcusaf's Avatar
Default RE: Think I may have a transmission problem.
hah I think I fixed the problem. I checked my coil to make sure everything was good on the spark side of the house and noticed the brown wire had come loose and fallen next to the distrib. I plugged it back in and took it for a spin around the block. It didn't stutter at all. Going to drive it around a bit more and make sure that was the only issue.
Hope you all had a merry christmas.
Old Dec 26, 2008 | 10:20 PM
Rich G.'s Avatar
I was reading your post and thinking it sure doesn't sound like a trans problem. Isn't it great when you think the worst and find out its something stupid. We should be that lucky all the time!
Old Dec 28, 2008 | 02:10 PM
SCHOON's Avatar
While you are at it you might want to check all your electrical connections.
Old Dec 28, 2008 | 07:04 PM
Rickcusaf's Avatar
That's the very next thing I did. All were nice and tight. I had my car worked on recently and my distributor was removed and repositioned. I think the mechanic forgot to push the connector back in all the way.
-Rick
joeyjc4
Jul 11, 2010 02:29 PM
Killer_Ride05
Nov 15, 2007 07:09 PM
rjensen
Sep 1, 2006 01:46 PM
Eagle223usa
Jul 5, 2005 12:26 PM
