Timing for a 72 454?
Old Sep 9, 2008 | 06:24 PM
  #11
JanS's Avatar
Default RE: Timing for a 72 454?
Great that expaines it now! All I have to do is eliminate those wires and run a 12 volt source from the fuse block that hasa full 12 voltsin the start andrun position. Guess I could try and trace the red wire back and run a 12 guage wire like the instructions say.
Old Sep 9, 2008 | 09:30 PM
  #12
Just replace the resistance wire with a 12 ga wire and you should then have 12V on the coil both in Run & Start.
Old Sep 10, 2008 | 12:56 AM
  #13
Wedge's Avatar
Hope this helps... J= October, 17=17th day, 1=1971, clock at 2= 2pm. This should be located on the flange behind the manifold above the bellhousing on the passenger side. On the other side should be the block casting number 3999289 if it is the original block for the car. On the stamp pad in front of the passenger rocker cover will be part of the vin with a letter suffix code: CPH was for 4 spds.
[align=left] [/align]
C3 Starship
Feb 5, 2007 03:04 PM
231SIX
Aug 21, 2006 10:18 PM
twitch2k6
Aug 19, 2006 12:53 PM
Bearcamp
May 29, 2006 09:20 PM
71yellow454
Apr 4, 2006 02:57 AM
