water pump pulley????
Old Mar 18, 2008 | 04:04 PM
flyboy1024's Avatar
Default water pump pulley????
just got some new aluminum pulleys for a short water pump, i have a 74 with a 350 5.7l, the whole in the center of the pulley is to small and the 4 holes for the bolts are closer together then mine, does this mean i have a long neck water pump??????????? thanks
Old Mar 18, 2008 | 04:29 PM
Default RE: water pump pulley????
My understanding is that the BB's have the long and short waterpumps. I believe that the SB waterpumps are the same size. I can't explain why the holes don't line up though. It may have something to do with the volume of water that the pumps are designed toput out, as to what application.
Could also be determined by how many accessories are run off the water pump pullies.
Old Mar 18, 2008 | 09:45 PM
DryCreamer's Avatar
Check this out:
http://store.summitracing.com/partde...p;autoview=sku
If you read the notes:
Notes: Will fit 1955-1974 Corvette models with 5/8 inch shaft. Bolt circle is 1 3/4 inch. Pulley depth 2.75 inch.
When pricing my water pumps, I came under the assumption that the little nub on the end was bigger on a Corvette, and when I actually disassembled my old one, it has, like, a plate on the back of the little turbine inside, I guess to prevent cavitation, so maybe it has a bigger bearing or something, but the Corvette def. lists a different water pump part number than a "standard" short water pump at the parts store.
80strat
Jan 14, 2007 08:36 PM
231SIX
Aug 23, 2006 12:57 AM
73Vette
Aug 14, 2006 01:11 AM
duneadx
Jun 26, 2006 07:13 PM
farhan
Oct 7, 2005 02:54 PM
