What is the best way to remove old dye?
Old Oct 3, 2006 | 01:23 AM
pg's Avatar
Default What is the best way to remove old dye?
My door panels were previously sprayed with interior dye, now I have some chips and I'd like to remove that
old dye so that I can start again on a clean surface, does anyone no what to use to get the old dye off?
Old Oct 4, 2006 | 12:16 AM
drdenny's Avatar
Default RE: What is the best way to remove old dye?
Maybe acetone may work. Good luck
Old Oct 4, 2006 | 11:30 PM
pg's Avatar
Hi drdenny, Okay, I'll give it a try on a small area, ThanksPG
Old Dec 31, 2006 | 03:02 AM
Phils76Vette's Avatar
If the dye isn't put on in some kind of thick coat or something. Why wouldn't you just scuff them up, prep them and then re-dye them the color you want?
I am changing from Red interior to Black. I am covering the factory color with interior primer and a black dye and it seems to have come out looking like a factory job.
Anyone know of drawbacks that may occur down the road, from a home dye job? I'm a mechanic head and interior is a "learn as I go" kind of thing right now.
Old Dec 31, 2006 | 05:36 PM
wrwalke's Avatar
There is a nice primer from Krylon specifically for vinyl and plastic... works wonders. I scuff the original, primer, scuff and then dye. haven't had any problems with it yet. Some solvents will damage the plastic and vinyl, making it almost impossible to paint afterwards (acetone, Oops, ketone, etc.).
bill.
Old Dec 31, 2006 | 07:11 PM
Acetone will defenately melt ABS. I don't know exactly what the compound is for the panels, but you could try it on the back side and see if it affects it. I found that most solvents are damageing to these types of materials. perhaps you could use a media blaster. Maxi-blast makes a plastic media that will not damage the underlying material as it is relativley the same hardness. Good luck with your project.
Old Jan 2, 2007 | 02:34 AM
pg's Avatar
When you say scuff and prime and scuff and paint, but scuff with what?
carid
Nov 19, 2014 06:54 AM
bpowelltx
May 16, 2012 09:23 PM
ax
Jul 6, 2007 10:51 PM
bill
Jul 28, 2006 02:19 AM
