will these wheels fit
Old Feb 28, 2007 | 01:39 AM
whiteray's Avatar
Default will these wheels fit
15x10 with negative offset rims and 235/65/r15 tires
on back of course
Old Feb 28, 2007 | 09:56 AM
Default RE: will these wheels fit
Main thing to look for, IMO, is that they don't rub on the calipers.
Old Feb 28, 2007 | 03:41 PM
pg's Avatar
Hello Whiteray, You need the check the " Backspace" Just pull off the rim that's on the car now, then put a straight edge across the inside rim of the back and measure down to the lug hole then measure the new wheel. Or do like C-3 says and slap it on the car and make sure it doesn't rub.
I have 15' by 10' rims and 255/60/15's on my car and they fit fine. Hope that helps, PG.
Old Feb 28, 2007 | 09:19 PM
Also, the ribs on the inside-backside of the rims is critical.PG is right about measuring the back space, just try the rims on for fit. You can do this prior to mounting the tires. You might check with Summit Racing for rims to fit a C3.
Old Mar 3, 2007 | 01:40 AM
You also want to check to see that the tire clears the parking brake cable mount on the side of the trailing arm. It can be moved to the top of the trailing arm for more clearance but requires a little welding.
Hxcxsince10
Sep 16, 2012 03:57 PM
seapup0
Oct 25, 2006 05:56 PM
RickC5
Mar 20, 2006 02:11 AM
JK1066
Dec 2, 2005 10:00 PM
WantAZ06
Nov 3, 2005 05:18 PM
