what do these codes mean
Old Oct 21, 2006 | 05:04 PM
seapup0's Avatar
Default what do these codes mean
BO-RFA 2100, 2105, 2110, 2115. H C
Can't find any info on them. I pulled these on my 02 c5. They were the last set of codes.
Old Oct 21, 2006 | 08:16 PM
gorichb's Avatar
Default RE: what do these codes mean
well I could be entirely off on this, and I'm sure I'll be corrected.
I pulled them up using the letter "P" in front of them and came up with this.
Like I said I could be wrong
2100 = TAC MOTOR CIRCUIT OPEN
2105 = TAC SYSTEM FORCED ENGINE SHUTDOWN
2110 = TAC SYSTEM FORCED LIMITED RPM
2115 = TPS PEDAL POSITION SENSOR/SWITCH D MIN.
Old Oct 22, 2006 | 12:36 PM
seapup0's Avatar
Can anyone expand on what the tac motor and system is? Can it be causing my active handling to engage for no reason?
Old Oct 23, 2006 | 09:39 AM
Are these C, U, or P codes? TAC is Throttle Actuator Control. [8D]
Old Oct 23, 2006 | 01:04 PM
gorichb's Avatar
I did use the "P" for the code, and it will definately make a difference in what it is if the letter is a "C" or "U".
How are you bringing up the codes? What scanner are you using?
Old Oct 25, 2006 | 05:56 PM
seapup0's Avatar
I brought up the codes by turning on the switch and checking codes with the dic buttons. Unfortunately, I cleared all codes after writing them down and they have not come back so I don't know what letter was in front of them.
1974corvetteowner
Feb 24, 2008 05:04 PM
rjensen
Sep 4, 2007 11:15 AM
whiteray
Mar 3, 2007 01:40 AM
RickC5
Mar 20, 2006 02:11 AM
WantAZ06
Nov 3, 2005 05:18 PM
