1985 fuel leak
Old Apr 20, 2020 | 08:18 AM
jerrysdustydog's Avatar
Angry 1985 fuel leak
Bought the car with a slight fuel leak and it looked like it was the rear drivers side injector seeping around the upper O-ring. Changed the injectors (what a pain) and found it probably wasn't leaking where I though. Fuel appears to be leaking from the rear of the fuel rail from the connection to the, I'm guessing, fuel return line. It's tight, so my question is there an o-ring in this connector? Would appreciate your help, I'm at my wits end!
Old Apr 21, 2020 | 11:00 AM
While it is probably an O-ring, you'll probably have to disconnect it to find out. But you're probably going to have to disconnect it to diagnose it anyway. If it is an O-ring, be sure you get one that is tolerant of today's alcohol contaminated fuel.
Old Apr 22, 2020 | 09:01 AM
Thanks for the reply, Stopped by NAPA yesterday and they show a "fuel rail o-ring" set, so I got them to order one, came in this morning and there are several 'o-rings' in the box, so the fuel rail assembly has many of them. Looks like I found the fix. Again, thanks for assisting! Maybe I will get to drive the car after all.
Old Apr 22, 2020 | 10:18 AM
Did you happen to find out if their alcohol resistant? Let us know if they fix your leak problem.
HeadstrongMS
Corvette C5 Z06
Feb 28, 2008 09:41 PM
ken93vette
Nov 15, 2007 10:39 AM
91c4guy
Mar 14, 2007 11:48 PM
ssa919
Jul 14, 2006 09:35 AM
KillaCam
Feb 25, 2006 10:47 AM
