1986 won't start
Old Sep 18, 2021 | 09:12 AM
RBarber133's Avatar
Default 1986 won't start
Had to change fuel pump, getting good pressure. Engine cranks but won't start. Check Engine light stays on. When using a code reader only getting a code 12. Tried disconnecting TPS, won't quite start, alot of popping though. Could PROM be bad on ECM?
Old Sep 19, 2021 | 03:13 PM
Welcome to the forum. Why did you have to change the fuel pump?
An engine needs three things, fuel, air, and spark. Since you seem to have fuel pressure although I don't know what you mean by good pressure. I guess you could either pull an injector or a spark plug and see if you're actually getting fuel in the cylinder. The next thing to check would be to see if you're getting spark.
LRC1987
Mar 21, 2021 11:22 AM
bighank
Jul 9, 2018 12:48 AM
fatdesoto
Aug 29, 2016 03:52 PM
rcole
Oct 16, 2006 09:37 AM
giacc
Sep 17, 2006 08:54 PM
