1987 ABS Issues/Can anyone help
Old Dec 22, 2006 | 10:16 PM
pattor's Avatar
Default 1987 ABS Issues/Can anyone help
I have a 1987 that is experiencing a brake issue. It pulls to the right when the brakes are applied. All of thecalipers have been replaced and none of the pistons are stuck, so I know it is not the calipers causing the issue. I took the car to the shop and they claim it is the hydrollics in the ABS system, and that I need a new hydrollic unit. Is there anyway I can disconnect the ABS system to see if the issue goes away? I just want to know for sure that this is the real cause of the pulling before I spend the money for the replacement part. I have already tried removing the fuse from the ABS system, but the brake issue is still there? Can anyone provide me with an idea?
Thanks,
Pat
Old Dec 22, 2006 | 11:17 PM
Default RE: 1987 ABS Issues/Can anyone help
You probably have a brake hose that is restricted. The one opposite the way the car pulls. Try that first since brake hoses are much cheaper than the ABS valve, if you can find one. [8D]
AHARRIS728
Apr 28, 2013 10:56 PM
jondi
Sep 16, 2012 11:46 PM
all84vette
Feb 17, 2007 05:34 AM
StringRay75
Nov 22, 2006 06:17 PM
Eagle223usa
Jul 2, 2006 11:21 PM
