1990 air conditioning
Old May 16, 2007 | 10:40 PM
cranky42's Avatar
Default 1990 air conditioning
Hey guys can anyone tell me how much R134 i need for my vette? along with how much oil i should put in?
should can of freon be upside down while filling system to fill with liquid or upside right for filling with gas?
thanks in advance
Old May 17, 2007 | 06:42 AM
Default RE: 1990 air conditioning
You shouldn't add any oil unless you have replaced a component. Also, the car only holds about 2.2 lbs after conversion or 80% of R12 capacity. Is the car not cooling or you have a freon leak? I wouldn't just add freon without checking low and, more importantly high side pressures. Ideally, you would like around 30 to 40 lbs on low side and 175 to 225 on the high side if your cooling fan is working properly and the system has no restrictions. You will get variations on both high and low. This is where experience comes in at looking at pressure readings. [8D]
chairman05@aol.com
Aug 23, 2006 11:41 PM
chairman05@aol.com
Jul 29, 2006 10:16 PM
jd2000
Dec 11, 2005 04:15 AM
vettemanrob
Sep 13, 2005 09:59 PM
GEORGE
Sep 5, 2005 10:58 AM
