1990 AIR CONDITIONING
Old Aug 23, 2006 | 04:12 PM
chairman05@aol.com's Avatar
Default 1990 AIR CONDITIONING
NEED HELP!!! I RETROFITTED MY 90'S AIRCONDITIONING TO R-134 ,NOW THE COMPRESSOR WILL NOT ENGAGE,I;VE REPLACED THE LOW AND HIGH PRESSURE SWITCHES AND THE COMP. CYCLING SWITCH.I HAVE 45 LBS. PRESS. AT THE LOW FITTING.ANY IDEAS? TO HOT TO DRIVE CAR WITHOUT THE AIR.
THANKS WAYNE K.
Old Aug 23, 2006 | 11:41 PM
Default RE: 1990 AIR CONDITIONING
What is your static high side reading? If both are 45 lbs, then you don't have enough freon in system. Should have around 80 - 90 lbs static pressure (that is line pressure before compressor starts pumping). Unplug cycling switch from accumulator and short terminals together to see if compressor comes on. [8D]
cranky42
May 17, 2007 06:42 AM
chairman05@aol.com
Jul 29, 2006 10:16 PM
jd2000
Dec 11, 2005 04:15 AM
vettemanrob
Sep 13, 2005 09:59 PM
GEORGE
Sep 5, 2005 10:58 AM
