1993 Corvette AIR removal & EGR
Old Oct 2, 2025 | 12:19 PM
carguy1965's Avatar
Default 1993 Corvette AIR removal & EGR
I have removed by secondary AIR pump located left front. I have also eliminated EGR and blocked off the two positions on the back of the motor and the manifolds. I am currently waiting for the plates that block the two position on the back of the motor. Other than an SES light that I will correct, what am I to expect once I start this vehicle ? How will the drivability be? I have heard some good and some not so bad stories.
Old Oct 3, 2025 | 11:52 AM
I don't know but I would suspect that you would get at a minimum, some O2 sensor faults.
Old Oct 8, 2025 | 07:01 AM
carguy1965's Avatar
Originally had a H26 Code but I reattached the plugs that go to the air pump and placed it back in its original place with no plumbing attached and the codes are now gone.
TEXAS HARRY
Technical Diagram Help
May 17, 2010 11:29 AM
xfasteddiex
Jan 2, 2009 10:53 PM
xfasteddiex
Jan 2, 2009 10:50 PM
mjames
Nov 13, 2008 12:12 PM
ZR1clone
Jul 17, 2008 08:23 PM
