unplug EGR solenoid?
Old Jul 9, 2008 | 07:41 PM
ZR1clone's Avatar
Default unplug EGR solenoid?
I was reading another post and was wondering what would be the consequences to disconnecting the EGR solenoid plug. What about removing the vacuum hose from the valve? Can someone please describe the consequences good and bad... Thanks-Kevin
Old Jul 12, 2008 | 01:51 PM
rshiver's Avatar
Default RE: unplug EGR solenoid?
My understanding of the the EGR (Exhaust Gas Recirculation) is this...It recirculates exhaust gasses back into the combustion chambers, and being that the exhaust gasses won't burn, it tends to help cool the combustion chamber. If the EGR valve is unplugged, or not operating properly the combustion chambers can get hot enough to cause detonation (engine ping). When the knock sensor mounted on the engine block detects the pinging, it in turn retards the timing to try and stop the pinging, in effect reducing engine performance. So, in my humble opinion, the EGR plays a vital role in optimal engine performance.
Cheers
Old Jul 13, 2008 | 11:25 AM
scooterman's Avatar
exactly right- i replaced the egr valve after uplugging. i just wanted to make sure it was the problem causing my stumble
Old Jul 17, 2008 | 08:23 PM
ORIGINAL: ZR1clone
Why do you want to remove it? You trippin' a 32 code?
runnerboy07
Dec 2, 2012 07:49 AM
mjames
Nov 13, 2008 12:12 PM
smithj4
Apr 7, 2008 07:42 PM
TopSpeed
Nov 23, 2006 04:50 AM
mikenann
Aug 23, 2006 11:35 PM
