3 questions on 1985 4+3 manual
Old Oct 31, 2006 | 03:48 PM
mercedes84black's Avatar
Default 3 questions on 1985 4+3 manual
1. my 1985, when at operating temp. sometimes the starter won't turn over, after sitting for 10-20 minutes she turns over fine. i know my clutch needs some adjusting, could it be the clutch or the starter needing replacement. 2. my tail light fuse keeps blowing, as soon as i put it in it blows. i know there's a short but which way do the wires run. passenger side fuse box to light switch to rear tail lights, please verify. 3. my 4+3 shifts fine 1st thru 4th but in reverse she will hardly move. how do you adjust the clutch linkage to correct this issue. any info greatly appreciated
Old Oct 31, 2006 | 03:53 PM
TopSpeed's Avatar
Default RE: 3 questions on 1985 4+3 manual
Your #1 issue mentioned *might* be due to a bad starter solenoid. I unfortunately don't know about your other 2 questions, but I am 1000% confident one of our fearless tech's will be along shortly to help you out there.
Old Nov 1, 2006 | 08:45 AM
i'd appreciate it if a little more info on this, especially the clutch and/or linkage adjustment. thanx
Old Dec 5, 2006 | 10:54 AM
mariogarcia@usa.com's Avatar
On the starter problem, your culprit is the clutch safety switch, I had the same problem. What I did, I just bypassed the switch with a wire jumperin the plug.
Old Dec 5, 2006 | 04:12 PM
Corvette_Johnny's Avatar
you hard starting when warm problem might also be a bad ground. you might consider taking the ground off and cleaning the ends or replacing the cable(s)
Old Dec 6, 2006 | 03:10 PM
About your taillights...check the wires at the bulb receptacle, there might be a wire strand touching the other wire, thereby shorting it.
rm1sner
Apr 5, 2012 09:50 PM
alchemy
Sep 25, 2010 07:36 AM
xlwhellraiser
Jul 22, 2006 03:34 AM
toroguy
Apr 1, 2006 01:35 AM
vettey
Jan 21, 2006 02:25 AM
