84 clunking noise
Old Oct 22, 2020 | 07:28 AM
jerbear1's Avatar
Default 84 clunking noise
I am new to the forum and have a 1984 with 19,000 mi on, super clean and runs great with the exception of a clunking noise that comes and goes when i decelerate from 35mph to 10. sounds like a lug nut inside a hub cap and follows the rotation of the wheel as you slow down, some times loud and other times not. I have taken it to two shops and of course they can't replicate the problem. u joints are all good and I have changed the diff fluid also and even changed the rear wheel bearings.any help would be greatly appreciated
Old Dec 28, 2020 | 11:08 PM
Welcome to the forum. Did you put the Posi-Trac additive in the diff.?
Old Jan 16, 2021 | 04:05 PM
jerbear1's Avatar
I did add the chev Posi-Trac additive when I changed the fluid to no avail thank you for your time am thinking it is the cat and will take that on next
Old Jan 16, 2021 | 11:09 PM
If it is a honeycomb cat then that's quite possible where the noise is coming from because they have a tendency to break into pieces.
Old Jan 24, 2021 | 06:46 PM
jerbear1's Avatar
TKS Ill let you know
Old Jan 24, 2021 | 09:19 PM
I remember that it helps to work the Posi-Trac additive into the clutches by driving in figure eights in a parking lot. You might try that if you don't find anything else.
Old Jan 27, 2021 | 10:55 PM
jerbear1's Avatar
I did that for about 20 min after I added the posi fluid, but tks, it did smooth out the noise when in tight turns
Clayton
Aug 23, 2007 11:19 AM
kemboz06
Corvette C5 Z06
May 2, 2007 01:56 AM
mypetu39
Sep 2, 2006 08:54 PM
Daveloves
Apr 29, 2006 04:32 PM
Daveloves
Oct 14, 2005 10:58 PM
