85 wont start
Old Oct 16, 2006 | 01:23 PM
blacknblue's Avatar
Default 85 wont start
We just bought a 85 corvette last week and it worked fine. The other day we drove it and came home and the car wont even turn over. The interior lights, radio, gauges, headlights work. Battery says 11.5 % and it tried jumping it from another vehicle. What is going on?
Old Oct 16, 2006 | 01:36 PM
Default RE: 85 wont start
First, Welcome to CF.
I would look first to the solinoid. Check to see if you have voltage there. If so, Solinoid is my thought.
Old Oct 16, 2006 | 01:39 PM
thespannerboys's Avatar
If all the gauges and stuff come on when you turn the key, and it says security or something like that, I think its the VATS key, (your ingntion key), this is just my guess, same thing happens to me every now and agian in my 86', I wait a few min then come back and it starts, Gotta have faith! [8D] im just to lazy to change it right now, doing other stuff to her!!! cheers
[IMG]local://upfiles/3562/955CC54D0A0649D4B1F991B91654580E.jpg[/IMG]
Old Oct 16, 2006 | 02:17 PM
All2kool's Avatar
I'd have to guess VATS as well as I have had other GM cars where this was the issue. The easiest way to correct this is to DISABLE THE DAMN VATS. A module can be purchased at any locksmith and can be installed within minutes. On my '89 Trans Am it took longer to remove the underdash cover than it did to install the module. The module, which is just a very small plug-in, shouldn't cost more than $25. Of course, you can have another key cut but if the problem is the contacts in the steering column, a new key will only be a temporary stop gap measure.
Old Oct 16, 2006 | 07:16 PM
blacknblue's Avatar
My key doesn't have a vats chip in it. I talked to a chevy technician and he thought that it was either the clutch sensor or the solenoid on the starter. He told me that there should be power to the purple wire on the solenoid when the key is turned, if there is not power, the clutch sensor is bad.
Old Oct 17, 2006 | 01:51 AM
wow I thought all vettes since 85 or 86 had VATS, I guess I was wrong
Old Oct 17, 2006 | 03:02 PM
blacknblue's Avatar
It ended up being a bad starter. The starter was fairly new. thanks for the help
Old Oct 17, 2006 | 04:09 PM
All2kool's Avatar
ORIGINAL: thespannerboys
It was the 1985 model year: http://www.drdetailshop.com/gmpellet.htm
I'd guess it has been disabled on this poster's car.
corvetteofcobts
May 25, 2012 06:00 AM
art1298
Oct 6, 2011 05:46 PM
hiax1971
Oct 9, 2005 08:45 PM
84C4
Sep 3, 2005 02:43 PM
84C4
Jul 23, 2005 11:31 PM
