'86 Chugging
Old Aug 4, 2021 | 10:30 AM
Gary J. Weinert's Avatar
Question '86 Chugging
Hi folks. So my '86, after it warms up runs fine at higher speeds but when I let up on gas it chugs. As soon as I step on the gas it goes away and runs fine at 50 and above. Slow down and it chugs.
Old Aug 5, 2021 | 11:52 PM
While it might sound counterintuitive, I would check the fuel pressure first.
Old Aug 6, 2021 | 12:19 PM
I will try that. Thanks.
Old Aug 6, 2021 | 12:47 PM
I had an 87 IROC-Z that would start fine but would hardly go until you got up to 30 and then it was just fine. It was the fuel pump.
If you don't have a fuel pressure gauge, you may pick one up at Harbor Freight for about $25.
Old Aug 6, 2021 | 03:27 PM
Hey thanks. I'll be checking that out.
Old Aug 6, 2021 | 10:59 PM
Let us know what you find.
Old Dec 4, 2021 | 10:37 PM
Fred W.'s Avatar
Check your EGR valve. It's supposed to open under acceleration and close on deceleration. It could be stuck open and feeding exhaust into the intake at inappropriate times. A vacuum gauge tee'd into the EGR vaccuum connection and taped to your windshield will reveal this.
Old Dec 5, 2021 | 08:08 AM
Default '86 Chugging
Thanks Fred. Will give it a shot.
Old Dec 5, 2021 | 09:36 AM
Even if vacuum is present, the EGR valve could still be stuck. You'll probably have to just remove it and visually check to see if it's stuck open.
How did the fuel pressure check out?
vette84vette
Jun 21, 2014 05:50 PM
chuck
Mar 7, 2010 05:42 PM
KeysGirl
Feb 10, 2008 03:45 PM
benbone
Jan 6, 2007 05:24 AM
alienbeing316
May 9, 2006 02:12 PM
