86 won’t idle
Old Aug 11, 2021 | 07:38 PM
Hoosier919's Avatar
Default 86 won’t idle
Hi everyone. I apologize for being “that guy” who posts a problem with his second ever post but I am struggling.
I recently picked up an 86 Automatic with some issues. The car will not start without giving it a couple of pumps to the throttle then it will not stay running without a little throttle. The dash is out so I don’t know how many revs it takes to keep it going. I’ve checked fuel pressure and I get 40 psi at key on and it stays there while running. I replaced the MAF after reading some posts and it is a fairly cheap and easy swap.
I had the codes pulled and this is what I found:486311045
Code
Loss of 24x signal
Dtc 36
Loss of e spark signal 2
Mass air flow sensor burnoff circuit 4
Dtc 43 low voltage electric spark control
44 lean exhaust left side
45 rich exhaust left side
46 power steering pressure switch failure
51 faulty prom ecm/ pcm
52 ecm temp low temperature
54 fuel pump mixture or ecm fault
Egr solenoid #2 failure
with all the ECM related codes I decided to swap that out too. Still no change
Additionally. There is a lot heat around the center console and it will dump black smoke if revved
Old Aug 12, 2021 | 09:36 PM
Not really sure why pumping the accelerator has any effect on it whatsoever since it's fuel injected. Have you tried holding the accelerator partially open while trying to start it? The black smoke indicates that it's running way rich.
The heat coming from the console probably indicates that there is an opening someplace underneath where air is coming from the engine compartment.
Old Aug 16, 2021 | 10:35 PM
KTM rdr's Avatar
Try replacing your IAC valve. Sounds like your running way rich. They have been known to cause issues. They're cheap and easy to replace.
Old Aug 17, 2021 | 06:49 AM
Hoosier919's Avatar
I picked up a new IAC valve this weekend. The old one is scarred up like someone took it off with channel locks. I am waiting on the new throttle body gasket to put it all back together
Old Aug 17, 2021 | 03:45 PM
Ductape's Avatar
Get an original service manual. They are very helpful. If you replace the IAC, check the voltage on the TPS (throttle position sensor) as well. Between those two items you might fix a lot of your problems.
Old Aug 17, 2021 | 05:28 PM
Let us know how that works out.
Old Aug 17, 2021 | 08:58 PM
Be sure to clean the throttle body while it's off.
Old Aug 18, 2021 | 06:04 PM
Hoosier919's Avatar
I have the service manual. I cleaned the throttle body and replaced the IAC. After I reinstalled the throttle body I adjusted the TPS voltage to 0.54. The car still won’t idle. I have checked all over for vacuum leaks and haven’t found any. I have ordered a cable to be able to connect to the OBD1 so I can read the codes again.
I think I probably have an exhaust leak as well. The center console gets so hot that after running it for a while tonight the carpet was getting burnt
Old Aug 18, 2021 | 08:14 PM
Ductape's Avatar
Hmmm. Have you tried spraying something like carb cleaner around the intake area to see if the idle (such as it is) changes? That's how I found a vacuum leak once. Fooled me.
Old Aug 18, 2021 | 08:16 PM
Ductape's Avatar
Shoot me an email weyer85@aol.com - ductape
