86 won’t idle
Old Aug 18, 2021 | 11:56 PM
  #11
You can also use an unlit propane torch.
Old Aug 19, 2021 | 09:00 AM
  #12
Hoosier919's Avatar
I used propane to check for vacuum leaks and and other than one line I forgot to reconnect on the throttle body I didn’t find any leaks
Old Aug 19, 2021 | 11:12 AM
  #13
Can you check timing?
Old Aug 19, 2021 | 11:17 AM
  #14
Hoosier919's Avatar
I haven’t checked the timing yet. I have asked around if any of my friends have a timing light but so far no luck. I will be picking one up soon if I don’t find one to borrow
Old Aug 19, 2021 | 01:59 PM
  #15
Ductape's Avatar
If nothing else, mark the distributor, loosen it a bit and (while it's running) move it a tad either way to see what happens.
Old Aug 20, 2021 | 03:44 PM
  #16
Isn't the timing controlled electronically on this engine?
Old Aug 20, 2021 | 04:02 PM
  #17
Ductape's Avatar
I believe there is some control, but not complete. I do know if the distributor isn't put back just right, you'll have trouble.
Old Aug 23, 2021 | 09:37 PM
  #18
KTM rdr's Avatar
Does this year have the opti-spark? I don't remember when they started using that.
Old Aug 24, 2021 | 07:29 PM
  #19
Ductape's Avatar
1992 started the optispark problem.
avgjoe
Dec 14, 2008 10:42 PM
firedragon78
Sep 25, 2008 04:11 PM
Bagpipingjake
May 20, 2007 03:01 PM
ShadowF1
Jan 24, 2007 07:13 PM
catadioptric
Jun 25, 2006 01:17 AM
