87 hood release
Old Dec 24, 2010 | 11:22 AM
stanleyz's Avatar
Default 87 hood release
My hood is sticking. IE: i pull the release and it does not open, If I pull the release and at the same time exert a little pressure upward it will come up and then open as normal. Cables and releases look fine and everything is well lubed. 2 questions, could the springs on the hood need replaced ? 2. There are what look like screw driver cuts on the end of the shafts on the hood, are they somehow adjustable? Thanks
Old Dec 24, 2010 | 05:01 PM
partsman41's Avatar
Sounds like the shafts are out of adjustment. Yes the slot in the end is an adjustment there's a locknut on the shaft at the top where it enters the mounting plate. The plate also has slots that allow it to move around to center the shaft in the latch. Possibly a close inspection of the socket might show where the shaft is binding not allowing the spring to pop it up when you release the catch. My 84 is doing the same thing,I've adjusted it but haven't hit the sweet spot yet.
Ron
Old Dec 25, 2010 | 07:55 AM
stanleyz's Avatar
Ron
Great, thanks. I'll get right on that. Something easy and cheap, now that's unusual.
Old Jan 22, 2011 | 02:08 AM
wrencher's Avatar
Try putting white grease on the stricker/shaft & close hood reopen & check the area is hitting & adjust latch
sc6654
Nov 29, 2007 02:31 PM
Glen Green 65
Jun 10, 2007 09:21 PM
taz7nads
Sep 7, 2006 11:37 PM
flower
Jun 23, 2005 02:57 PM
