88 vette-engine misses & sputters
Old Oct 19, 2007 | 09:05 AM
slobbering_walrus's Avatar
Default 88 vette-engine misses & sputters
HELP!!! PLEASE!! My 88 corvette got water in gas tank. I drained tank 2 times, put new fuel filter, new distributor cap, new plugs, new wires, new rotor, added fuel additives(high dollar), and the engine still won't run properly. It misses and spits and just will not run. What can I do now? I am at a total loss.
Old Oct 19, 2007 | 09:12 AM
red90vettesc's Avatar
Default RE: 88 vette-engine misses & sputters
Did you run the water thru the fuel injectors before you realized what had happened? I had a friend this happened to and it fried his injectors.
Old Oct 19, 2007 | 09:18 AM
rshiver's Avatar
Hi slobbering_walrus, and welcome to the forums.
I would say that after draining the tank two times, and all the other things you've done, I would pretty much rule out water in the gas being your problem.
I guess to start with, is your check engine light coming on? The first thing I would do is check is the fuel pressure, it should be around 30 to 35 psi. It would be a good starting point in finding your problem.
BTW...I'm curious, how did you discover you had water in the tank?
Old Oct 19, 2007 | 10:12 AM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Oct 19, 2007 | 10:19 AM
LeesVette's Avatar
I would check the plugs then the injectors. Are you sure your getting constant fuel pressure when its running?
Old Oct 19, 2007 | 11:06 AM
Yes I had already started the engine when I discovered water had gotten in the gas.
Default [Deleted]
[Deleted by Admins]
Old Oct 19, 2007 | 11:10 AM
LeesVette's Avatar
ORIGINAL: Snow Wolf
ORIGINAL: LeesVette
Did I not just post that abotu a hour before you did? LOL. Just kidding with ya....
Better check your time stamp so I don't call you a liar.
Old Oct 19, 2007 | 11:12 AM
I have changed the plugs twice. I have no idea how to check the injectors. Is there an easy way to do this?
Old Oct 19, 2007 | 11:18 AM
My worst fear! The injectors are not old, but if they are fried?? I am curious about the guy who fried his. This could be my problem. I have not check fuel pressure. Could my fuel strainer be stopped up?
