89 with weak injector pulse
Old Sep 20, 2006 | 07:03 PM
racn97's Avatar
Default 89 with weak injector pulse
I have two 89 both with hard starts been from one end to other im at the end of my rope, every thing checks fine the noid light blinks so dim you can barley see it .I have checked all grounds swapped every known part from a good running car . any help please
Old Sep 20, 2006 | 10:32 PM
Default RE: 89 with weak injector pulse
Have you checked the voltage supply on the injector harness with a volt meter? KOEO. Should be B+. ECM supplies ground. If you have B+, then your stator in the distributor might be suspect. Low signal voltage (A/C) means low or narrow injector pulse. [:-]
bighossvetteman
Jun 12, 2011 09:31 AM
TX Mike
Dec 21, 2008 02:56 PM
TX Mike
Dec 21, 2008 02:52 PM
deansmachine
Sep 11, 2008 07:08 AM
DeeVeeEight
Feb 15, 2008 12:08 PM
