92 won't start
Old Mar 6, 2009 | 04:40 PM
Tom G's Avatar
Unhappy 92 won't start
After being in winter storage I charged my battery and started my 92 and was letting in run. I got involved in something else and forgot about it running. It was on reserve so it did not have much gas in it and ran out. When I later remembered, the battery was dead. I charged the battery, but now it won't start. Can you burn up the fuel pump if you run out of gas and the key is still on?
Thanks
Tom
Old Mar 6, 2009 | 04:51 PM
95C4's Avatar
Default No Start
Yup,
Hopefully the fuse went first.
If the pump is OK and fuse not blown, you should hear the pump run for about 2 seconds after turning the key to run (not start).
Old Mar 6, 2009 | 06:26 PM
LeesVette's Avatar
Have you checked to see if you have fuel pressure at the rail?
Old Mar 7, 2009 | 07:07 AM
Tom G's Avatar
This is my first vette and I know little about mechanics. What is the rail?
Old Mar 9, 2009 | 08:20 AM
LeesVette's Avatar
The fuel rail. The fuel lines come in from the passenger side. The lines run into the fuel rails that lay on both sides of the engine (over or just to the inside of the valve covers. the sit above the fuel injectors. The injectors are plugged into this rail. On the passenger side rail there is a Schrader valve. You take a fuel pressure gauge and screw on to this valve. Then you can check your fuel pressure to see if you are getting fuel to the rails.
Old Mar 12, 2009 | 05:03 PM
Tom G's Avatar
Originally Posted by 95C4
Yup,
Thankyou,
The fuse was blown - replaced it but still not running. It does run for a few seconds with ether. Must be fuel pump
Old Mar 12, 2009 | 05:06 PM
Tom G's Avatar
Thankyou,
It appears that it is not getting fuel, for it will run a few seconds with starter fluid. I think I know someone with a fuel pressure gauge.
Old Mar 14, 2009 | 04:11 PM
xfasteddiex's Avatar
tom turn key on & push scraider valve in just like letting air out of a tire but its fuel instead , wear safty glasses.
Rick854
May 2, 2006 01:28 AM
buckeyevette
Mar 22, 2006 11:45 PM
Barry
Mar 12, 2006 03:05 AM
raisinbran
Dec 17, 2005 02:48 AM
PHILC
Nov 20, 2005 11:18 PM
