93 cooling system
Old Sep 3, 2008 | 02:31 PM
RobRod's Avatar
Default 93 cooling system
Im looking to replace all of the hoses on my 93 vette including upper and lower radiator hoses,throttle body has a hose that runs up to it (can i delete this?),and the heater core hoses now ive looked at alot of websites and cant seem to find a direct replacement any suggestions
-Rob
Old Sep 3, 2008 | 11:06 PM
Default RE: 93 cooling system
Suggestions for replacement hoses? Nope; don't know.
BUT, when you pull the old ones off of the heater core nipples, be VERY careful - you can crack the joints at the core, and ruin the core. Gargantuan PAIN to replace...
Pinch a little of the hose with some pliers, and spray some armor all at the hose end. It will get back in under the hose, and then you can just pinch the hose a few more times, and it will work loose. Make sure you have no pressure on the pipe itself, and DON'T twist. If the hose doesn't easily slide off, push onward, and it should break free the rest of the way.
Marks95corvette
Sep 18, 2011 01:01 AM
zora55_56
Jul 21, 2007 11:08 AM
blueshark
Dec 25, 2006 09:23 PM
bertsbassbox
Aug 17, 2006 06:27 PM
350ZNV
May 8, 2006 05:58 PM
