93 Cruise Control
The cruise control has never work since i got the car 7 years ago. When you push the cruise button nothing happens, not even a click of electrics trying to work.
I have read on the various threads that there are multiple problems can interfere;
Vacum
Brake Switch
Cruise Module
Cruise Relay
Servo
With the exception of Vacum Hoses which would be the most likely problem part?
I am at the end of finishing multiple projects with my 93 coupe with greenwood package including engine rebuild with comp cam, roller rockers, AFR heads, 36# injectors. It is now in for painting including greenwood scoop, and hood vents.
Thanks
Ken
Vacum
Brake Switch
Cruise Module
Cruise Relay
Servo
Thanks
Ken
Follow the Helm's factory manual troubleshoot procedure. You can trace it down to the exact part here. In my case it was the connector at the end of going the wire going to the cruise control button. It is just a piece of circuit board and the wires are soldered. I re-soldered those four wires.
