Battery
Old Mar 28, 2006 | 12:43 AM
toroguy's Avatar
Default Battery
Hi again,
The battery in my 85 must be to tall?
It was been worn through from the hood rubbing on it from lack of clearance. Acid is leaking from the wound.
It is an Interstate side post battery - any recommendations? I guess I never considered the height of a battery before.
I like to keep things stock, is there a OEM battery?
Thanks again
Old Mar 28, 2006 | 03:37 AM
corvette king's Avatar
Default RE: Battery
optima red top, it is a dry battery and is short and fits perfict in a 1985. i have one in my 84 vette.comes with top and side posts...if you run a raido with amps get the optima yellow top deep cycle. bothe same size.
[IMG]local://upfiles/1664/93C6A34D5FBB4B8DA29A07230F9BFDB6.jpg[/IMG]
Old Mar 28, 2006 | 08:15 PM
Default RE: Battery
If it is an Interstate battery, should be a group 75 battery. Gray top is an MT-75 and green top is an 75-50. Those are the proper Interstate batteries for your car. If that is what is in there, then you need to look at the battery tray and make sure it is properly mounted. [8D]
Old Mar 29, 2006 | 01:05 AM
toroguy's Avatar
Default RE: Battery
Thanks guys!
I plan to remove the battery tomorrow to see what is up? I measured some batteries at Wal Mart - I will see what the deal is once it is out.
I'll report back with the findings
Lee Willis
Nov 20, 2006 11:44 AM
crvttbass
Mar 31, 2006 09:25 PM
1fast86
Jan 19, 2006 06:38 PM
indycar
Oct 6, 2005 04:58 PM
wellsw
Aug 4, 2005 10:00 AM
