Bcm went bad in my 94. Isnt the mileage stored there?
Old Apr 12, 2009 | 12:41 PM
uptons's Avatar
Exclamation Bcm went bad in my 94. Isnt the mileage stored there?
My body controle module is putting out some failure to communicate codes in my 94 lt1. So i am going to replace it. My question is isnt the odometer reading stored there? Will i have to take my vette to a dealership to reprogram the odometer back into the bcm? Any help would be appreciated.
Old Apr 12, 2009 | 06:02 PM
The BCM doesn't store mileage. That is in the speedometer assembly. BCM is for air bags, a/c and so forth. ON the newer cars, 98 and up the BCM has to be programmed, but not sure about the 94.
Old Apr 13, 2009 | 09:53 AM
Viscount's Avatar
I believe your referring to to the CCM, Central Control Module.
It controls quite a few electrical functions & if replaced it will have to programmed within X number of miles by a dealer or someone with the proper equipment.
Don't have the FSM handy & that's all I can remember.
Old Apr 13, 2009 | 09:49 PM
LeesVette's Avatar
The CCM has to be programmed with the correct mileage within 100 miles or you are locked out and you cannot change it after that.
Marc Badley
Jan 8, 2013 05:06 PM
KenHorse
Nov 11, 2007 12:03 PM
jagmanrino
Jan 19, 2007 03:13 PM
white88
Aug 31, 2006 02:56 PM
Vette93Racr18
May 1, 2006 01:40 PM
