Bleeding Air Pockets
Old Jan 10, 2007 | 02:41 PM
ernie22golf's Avatar
Default Bleeding Air Pockets
What's the best way to bleed the air from cooling system - I don't want the water to get into the Opti-spark when bleeding - what have ya'll done to keep this from happening.
Thanks
Old Jan 10, 2007 | 03:54 PM
raisinbran's Avatar
Default RE: Bleeding Air Pockets
I believe there is a bleed screw on the throttle body on the LT1s. You can also try pumping the upper radiator hose some until it fills with water.
Old Jan 11, 2007 | 01:44 PM
Viscount's Avatar
There is an air bleed valve on the top of the thermostat housing. It faces the pass/side of the engine. A small brass screw can be backed off slightly to vent air from the system. Just barely open it so as not to allow coolant to drip on to your opti-spark. This is done with the engine idling. May take a couple of shots.
Old Jan 12, 2007 | 11:05 AM
I checked the raditor through shroud and appears clean - my tempature varies quite a bit. Doesn't really get hot just 195 through 210 when not in traffic. I know both upper and lower raditor hoses were replaced before I bought the car so I think there may be some air pockets. I'll try bleeding the system. Any tips for keeping water away from opti-spark?
Old Jan 12, 2007 | 01:33 PM
Viscount's Avatar
The few times I've changed the coolant I just barely loosened the bleed screw on the thermo to let any air escape. Did this with the engine running. After shutting down the engine I fill the overflow container to the hot line. You may have to repeat this a couple of times. Worked for me.Some prefer to remove the bleed screw & fill the system until coolant runs out. If you use this procedure make sure you cover the opti.
JanS
Nov 1, 2008 09:40 PM
bertsbassbox
Aug 17, 2006 06:27 PM
brhino
Jul 18, 2006 02:41 AM
350ZNV
May 8, 2006 05:58 PM
tonyb
Aug 28, 2005 09:48 AM
