Bleeding Air Pockets
There is an air bleed valve on the top of the thermostat housing. It faces the pass/side of the engine. A small brass screw can be backed off slightly to vent air from the system. Just barely open it so as not to allow coolant to drip on to your opti-spark. This is done with the engine idling. May take a couple of shots.
I checked the raditor through shroud and appears clean - my tempature varies quite a bit. Doesn't really get hot just 195 through 210 when not in traffic. I know both upper and lower raditor hoses were replaced before I bought the car so I think there may be some air pockets. I'll try bleeding the system. Any tips for keeping water away from opti-spark?
The few times I've changed the coolant I just barely loosened the bleed screw on the thermo to let any air escape. Did this with the engine running. After shutting down the engine I fill the overflow container to the hot line. You may have to repeat this a couple of times. Worked for me.Some prefer to remove the bleed screw & fill the system until coolant runs out. If you use this procedure make sure you cover the opti.
