Broken thermostat bolt-85 Vette intake
Old Mar 22, 2006 | 01:13 AM
  #21
corvette king's Avatar
Default RE: Broken thermostat bolt-85 Vette intake
what i would do is buy a [ hel-coil] kit, they give you all u need in the kit,drill the hole out with the drill they give u,then tap it then insert the hel-coil and u eill never strip out or cross thread again,put some never cease on the bolts so they dont freez up on u again,check what size bolt then mach with kit.i use them a lot,when building motors i replace all the taped out hole in the heads with them, they are the best there is a penitration oil called [koil ]and that **** will unfreez any thing,i used it in the navy.spray it on let soak for 2-3 hours and bammmmmm it's loose,
[IMG]local://upfiles/1664/D08C7DCB3F7342A583BA66FF23914FDF.jpg[/IMG]
1974corvetteowner
Dec 4, 2007 02:18 PM
rsdonzi
Corvette C5 Z06
May 2, 2007 01:51 AM
bobbiebello
Aug 6, 2006 11:20 PM
srizzutto
Jul 7, 2006 09:27 PM
PAY2PLAY
Oct 10, 2005 06:58 PM
