C4 stalls after starting
Old Oct 9, 2012 | 11:07 PM
boo's Avatar
boo
Default C4 stalls after starting
After starting the car stalls between 3-4 min. Replaced the fuel pump relay, same result.
Old Oct 14, 2012 | 12:58 AM
Dommo's Avatar
Service manual suggest the fuel pump not the relay might be the problem you can get the pump without the sending unit its a whole lot cheaper and there is a nice write up about how to go about replacing it Not to diff. Just make sure you replace the sock at the same time its probably clogged and it may also be adding to the prob
Old Oct 14, 2012 | 10:19 PM
boo's Avatar
boo
Thanks! Figured I would replace the fuel filter too! Would the car start and run for 3-5minutes if it was the pump?
Old Oct 20, 2012 | 02:34 AM
annicorvette's Avatar
check the exhaust and cats. had the same problem on my 90, it would run for a short time then the exhaust would cut it off.
Old Oct 20, 2012 | 02:39 AM
check the exhaust - had the same problem on my 90 - the car ran fine till the exhaust heated and cloged let it cool and it would run for a short time again - i also started with the pump and filters
Darkracer
Feb 8, 2011 07:44 PM
bigtalos
Feb 4, 2011 03:50 AM
oliwa22
May 26, 2007 03:15 PM
AlJohnson
Apr 4, 2007 01:45 PM
