Car stereo help!
Old Jun 2, 2007 | 04:58 PM
khaki1967's Avatar
Default Car stereo help!
I have a 94 vette W/O the Bose system installed. I'm trying to upgrade the system with a new head unit and rear speakers. The first problem I encountered is the Infinity 9623i (6 by 9s) screw holes are slightly smaller than the original pair. Do I need to modify the body or are there speakers out there that have an exact fit?
Secondly, I purchased a Pioneer DEH-P3900MP along with a Metra BB-WH6M2 wiring harness that does not match my factory connector. My vehicle has two inline connectors (7 and 9 pin) while the purchased harness has two rows of terminals as one connector. I also had difficulty finding the shroud that houses the stereo and makes it look like it belongs there. Walmart sells a wiring harness from Schorsce? I think, that won't fit either.
I really don't want to start hacking wires to compensate or modify body panels if the right parts are out there. Thanks again for any ideas.
Old Jun 2, 2007 | 05:04 PM
LeesVette's Avatar
Default RE: Car stereo help!
I cannot help you with the problems you have listed but you do know that if you go aftermarket stereo you will need to insert a resistor to eliminate an SYS warning you will recieve?
Old Jun 2, 2007 | 09:03 PM
khaki1967's Avatar
Thanks for the response but I'm not aware of this. Where can I find more info about it?
Old Jun 4, 2007 | 07:06 AM
LeesVette's Avatar
This service bulletine says its for a 90-93 Corvette but I was under the impression a trouble code could be set for 90-96 cars if this resistor is not installed. Here is the link for the trouble code bulletine: http://www.corvetteforum.net/c4/dave8476/index4.shtml
Old Jun 12, 2007 | 05:27 PM
whytry's Avatar
the SYS warning will come on in a 94 too...
Old Jun 12, 2007 | 07:22 PM
Black86vette's Avatar
<<<<Lurking.
Nawz john
Mar 26, 2011 01:23 AM
91greenvette
Aug 2, 2007 08:42 PM
twillyC5
Jul 10, 2007 01:17 PM
njttz
Apr 17, 2006 02:00 AM
imb1987
Nov 20, 2005 05:32 PM
