cats
bought a 87 conv. with tons of probs.(fuel pump,8 inj.,coolant sensor,MAF sensor,IACV sensor,EGR value,TPS sensor).my guestion is there was a ton of carbon build-up in the intake i cleaned it as best i could,im thinking that the CAT.conv. are stopped up because it doesnt have that much power,can i gutt the CATS with out messing up the ECM.HELP PLEASE.
You can take the cats off, only problems you will have will be if your city has emissions testing and you might set an EGR code. ECM looks at O2 voltage readings when commanding EGR. It watches for a voltage change based on exhaust readings calculated with some backpressure produced by cats. Also on an 87, EGR uses backpressure along with vacuum to open EGR valve. [8D]
This is ONE of your cats. Yea all that from one you got two up front. Chop them off. Convert to true dual and have it WELDED NOT CLAMPED with some high performance mufflers NO FLOWMASTERS. They are not that free flowing as you think and have heavy drone.
[IMG]local://upfiles/3722/834802243BC24495A8E530CBC95F5841.jpg[/IMG]
I took a vacum cleaner and a tire tool adn busted those cats up. Good power and REALLY loud.
