Changing the Battery
Old Feb 18, 2009 | 01:47 PM
kev3636's Avatar
Default Changing the Battery
does anybody know how to remove the battery from a 1985 corvette?Do you need to remove the side body panel or the steel bar above it?
Old Feb 19, 2009 | 08:40 AM
rshiver's Avatar
You have to remove the side body panel.
Old Feb 23, 2009 | 07:56 AM
LeesVette's Avatar
There are a couple of bolts at the top of the side panel and there is one bolt on the bottom of the panel. The bottom bolt is in the crease between the rocker panel and side panel. DO NOT completely remove this bolt. Just loosen it up so you can slide the panel off. Make sure you get the panel realigned properly. If you don't and you open and close the door you will know about it.
kev3636
Feb 21, 2009 09:33 AM
gorichb
Aug 19, 2006 01:14 AM
50annv03
Mar 31, 2006 09:38 AM
kchotboat
Mar 22, 2006 01:44 AM
stonecoldsaysto
Jul 21, 2005 12:27 AM
