Changing out bulb, for Driving lights
I have the right side light out on my 98, and plan on changing them both at once. Looks like you have to go in from inside the wheel well. Just wondering if anyone has some quick tips to making this a little easier to get to, Thanks
From my archives....
"If you lift the hood.. and locate the front hood stops,( adjustable, silver in color with a black rubber stopper on top ) which are next to the headlights.. raise the headlight, remove the black plastic surround panel, and the hood stop.Removing the hood stop gives you a little extra room to get your arm down there. The fog light bracket is held in place with one 10 mm screw. the bracket has a centering locator clip on the top..
once the screw is removed, you can remove the bracket noting the locator tip on the top.. a quarter turn removes the bulb socket."
Dave
Dave
