Code 41
Old Jan 31, 2007 | 10:30 PM
motomaniac1988's Avatar
Default Code 41
About 3000 miles ago, I replaced the factory opti-spark with an aftermarket unit made by MSD. Everything was fixed, and recently, i have been having intermittent starting problems. My mechanic finally got it to not start and the computer shows a code 41 which he says has to deal with the opti-spark unit. Can any one help me out as to what might be going on under the hood. I really dont want to have to replace the unit again. Thanks
- David
1992 Corvette Coup wih 97,000 miles
Old Feb 2, 2007 | 10:50 AM
Default RE: Code 41
You might have a problem with ignition coil driver module. Code 41 is set when the ECM sees a voltage of higher than 4.6 volts on the white EST wire, which might be the driver is shorting out or your coil is creating unwanted voltage spikes.
mdsbch
Oct 12, 2006 01:20 PM
kggoodier
Jun 13, 2006 01:34 AM
94corvette
Dec 4, 2005 01:38 AM
Lee Willis
Nov 30, 2005 01:40 PM
jsteezy1290
Jul 28, 2005 12:28 AM
