cruise controll problems
Old Apr 11, 2007 | 05:27 PM
  #11
Default RE: cruise controll problems
84 is not controlled by ECM, but has it's own control module. There are still tests to check voltage supply through the column switch. Have to drop the driver side cover above brake pedal, unplug wiring connector to check voltage supply, the switch side you have to check continuity on all switch posistions which will be impossible to do unless you have information on which posistion has continuity on which pins.
Old Apr 11, 2007 | 11:19 PM
  #12
TNTs 84's Avatar
Sounds Like I would be better off letting the mechanic take a crack at this one. Thanks for the info.
mattzzusa
Jul 24, 2007 05:48 PM
serg5000
May 12, 2007 04:16 PM
serg5000
Apr 26, 2007 03:35 PM
bpmagnum
Aug 6, 2006 09:07 PM
knob
Jun 16, 2006 09:56 AM
