Distributor rotor screws
Old Jan 4, 2009 | 07:12 AM
camhar25's Avatar
Default Distributor rotor screws
Can someone tell me what kind and size of head is on the rotor screws. I am changing the water pump and capa nd rotor on my 95.I'm at a standstill right now. Looks like a small torx head but i can't get a bit to fit,and I have them all.Any help would be appreciated.
Thanks
Mike
Old Jan 4, 2009 | 07:19 AM
xfasteddiex's Avatar
Default RE: Distributor rotor screws
mike not sure on a 95 but my 90 is a 1/4 " socket, hope this helps
Old Jan 4, 2009 | 08:56 AM
camhar25's Avatar
Thanks for the reply, but these screws do not have a hex head.They have a recession.Tried to take pic so I could see what they are but the shot is to close.Anybody else?
Old Jan 4, 2009 | 03:53 PM
C2C3C4's Avatar
It's a Torx E4 deep socket. I got mine at the Auto Parts store. I think Vulcan is the brand. You might want to try Snap-on.
I just looked it up in the Snap-on catalog-It's a 1/4" drive deep Torx socket E4
Part # STLE40
Old Jan 5, 2009 | 06:12 AM
camhar25's Avatar
Turns out it was a T-8 Torx. The newMSD cap came with allen screws.
Old Jan 12, 2009 | 08:01 AM
LeesVette's Avatar
How many miles are on the opti that you put a new cap and rotor on? Why in the world would you just do a cap and rotor when you already had the water pump offand the engine tore down? If your going that deep you might as well do a whole new opti. Spend the extra cash and get a whole new opti instead of spending a couple hundred bucks fopr a cap and rotor which you will probably have to go back and put a whole new opti on sooner more than later. Just replacing the cap and rotor is a waste of time and money........
Old Jan 12, 2009 | 08:25 AM
ORIGINAL: LeesVette
what parts sotre do you use couple of hundred for a cap & rotor, man they seen you comming . i just did plugs ,wires ,cap, rotor,& coil for less than70
Old Jan 13, 2009 | 10:00 AM
camhar25's Avatar
I have 73000 miles on the 95. It really wasn't that bad of a job. I have a side business repairing.What brand of Opti do you recommend. Stock or aftermarket? The cap and rotor are MSD pieces.
Old Jan 13, 2009 | 10:46 AM
LeesVette's Avatar
ORIGINAL: xfasteddiex
ORIGINAL: LeesVette
What brand of cheap parts did you use to get all that done for $70.00? I would never do a cap and rotor but the cheapest I have seen is around $150.00 Hope you didn't use Delphi or AC Delco............
Old Jan 13, 2009 | 10:47 AM
LeesVette's Avatar
ORIGINAL: camhar25
I have the vented MSD. I have not installed it yet on my '92. I would go MSD but there have been some problems with some of the units lately.
